"Insert new sheet" issue
I have managed to set up my templates and everything is working with one exception. I have created a drawing where we are using the company logo (bmp format) in the title block. When I am in "A" size drawing and I want to add a new sheet which would be "B" size, the logo appears in two spots, one where it's supposed to and two where the A logo was. It's as if SW decided to forget to remove the logo from the A drawing when it was changing the properties of the second sheet to a B size.
Any ideas on this one? It really looks like a ...shhh...bug...
RE: "Insert new sheet" issue
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
This is why I don't use mixed size sheets, I keep them all the same size.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
ctopher's blog
Eric
I just checked and the bmp is on the sheet format and not the sheet. But when I saw this response, I reckoned that was my culprit.
Chris,
99/100 times we don't mix sheets but I am setting up the templates now and don't know what will happen down the road. I just want to cover this eventuality.
When I select add sheet from a drawing size A and then I go to sheet two and change the properties to a Size B, it's keeps the location of where the logo was in the A size.
Jeff,
I can go into Sheet 2, edit the format and remove the logo. But I'd prefer not to have this extra step.
Donal
See thread559-224853: auto insert 3 standard views? for details.
Have you submitted this to your VAR or SW?
