Lock Cell based on another cell value
I have some conditions in my calculations that I want to make a bit more user friendly.  I have conditional formatting set up to make the user choice visibly obvious, but I also want to conditionally lock cells based on values in other cells.
How would I go about doing that, if it is even possible?
--Scott
http://wertel.eng.pro
RE: Lock Cell based on another cell value
You could have an Event monitor macro running...i.e. in the API Sheet/WorkSheet/SelectionChange
Then use it to change the protection on a cell(s).
Ken
Thanks, I'll look into that.
--Scott
