Total of individual Part Numbers in a large assembly
I usually work in large assemblies, typically 5k to 10k parts count. What I have been unable to determine is the number of individual part numbers contained in those assemblies. Some of those part numbers, say for standard parts, will be used in several branches at different places in the product structure, and other parts will be used in arrays, so that there will be occurrences of the same part number in one assembly.
Short of exporting the content of the Assembly Navigator to a spreadsheet, and doing some filtering (I'm not good at this), and risking mistakes due to duplications, is there an easy way to do this?
Just to add a little complication, I also use suppressed components in assemblies, so I would like two different totals, with and without suppression.
Any thoughts?
NX4/TC9.1
Any thoughts?
NX4/TC9.1
RE: Total of individual Part Numbers in a large assembly
Note that I just tested the program on an assembly with nearly 12,000 components and it took about 10 seconds to report that there were only 977 unique components in the assembly.
BTW, this program was written in 1994 and last updated in 1997 although it appears that the copy that I have was compiled in 1999, AND IT STILL RUNS TODAY!!!!!
Anyway, if you're familiar with GRIP I could download a copy of the source code and it might give you a place to start (I'd volunteer to look into it myself except that I leave for vacation tomorrow morning and won't be back until September 8th).
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
977 parts from 12000 is a fair reduction. That means there are merely 977 parts to design/draw/procure/validate/configure/assemble and test. It makes the task seem almost do-able....
Enjoy your vacation.
Sorry to say that I guess I can help prevent you from wasting time but don't have any ideal solution readily to hand.
Surely NX Open programming using C or VB would support this kind of thing.
Had I wanted to do what the grip program does out of hand then I might have tried using the command line utility that comes with NX called ugpc.exe. Run from your DOS command line that will list the contents of an assembly. I think it works with your load options default file to find the components.
An extension of that is a program available on the internet called ugzipc. The website is below and he distributes the source with it as freeware. The program works as ugpc might but places the contents in a zip file of your hard disk. That is pretty cool in itself, but having the source may be useful to somebody as yourself who wants to do a similar task with a different output.
Cheers
Hudson
http://www.w-eng.de/ugzipc.htm
John R. Baker, P.E.
NX Design
Cypress, CA
If you need to do this often, I would look at investing some time to create a UG/Open program to break down the assembly and sort any way you would like.
-Dave Tolsma
http://Tolsnet.com/jobs
http://groups.google.com/group/NX_CAX/
http://groups.google.com/group/plm-exchange/
Cheers
Hudson
