how is B measured for BH loops?
Is B measured directly or indirectly? To measure directly using, say, a hall effect type probe you would have to modify the sample to accept the probe. The probe then would only measure the B in the modified area (filled with air, not the sample material). So I'm guessing it must be measured indirectly?
RE: how is B measured for BH loops?
I read a blurb that (I think) says that you measure the real power flowing into the winding, subtract the winding losses and assume the rest of the power produces hysteresis. But that would ignore eddy current losses. So I still don't quite get it. Can you elaborate on how B (flux density) is measured with the setup you described?
A closed magnetic circuit in this case means you place the material in an electromagnet and close the poles on the material. This forms a closed loop, as far as magnetics are concerned.
Here is a link to a website that shows a hysteresisgraph testing station (more appropriate for testing permanent magnets). There is a sample in the electromagnet but the poles aren't closed yet.
http://w
I'd like to measure the flux density flowing through the field's laminations as I try different sized materials around the field OD. I have a Gauss meter but its probe is a bit too thick to fit into the gap between the field and armature. I thought of machining a slot into the field for the probe but then the probe would only see the flux density flowing through the air in the slot. I was wondering how the measurement could be made without modifying the parts.
Electrical steel will act as a lower reluctance path, but it might saturate earlier than the steel. It's difficult (in my mind) to know for sure without FEA or actaully making the tube from electrical steel.
