Minimum Corona Free conductor sizes
Does anyone have a list/chart/reference standard for minimum corona free conductor sizes?
I will appreciate any information I can get.
RE: Minimum Corona Free conductor sizes
I know the EPRI Red Book has some info on it. I'll see if I can find it and post some additional info. If you're not an EPRI member, it will cost you a kajilion dollars! : )
Sorry, I don't have any charts or information.
Bill
"Why not the best?"
Jimmy Carter
See if the attachment comes through OK. This is Peek's equation or formula from 1929.
Actually I think that the effective radius (in terms of corona onset/avoidance) of a four-plex bundle is much greater than the actual radius of the conductors comprising the bundle. Hence my use of the term "effective radius".
Bill
"Why not the best?"
Jimmy Carter
Keith Cress
However I am not aware of any recent standards or references that may have this information to validate that data.
Thanks magoo for the equation. I will try it on a couple of conductors
A chart or table would be very handy or if you know of a standard name and number which may have this info.
say zazmat,
What voltages are you dealing with
and
Are they single conductor lines or multi-conductor bundles?
Eo = go·delta^(2/3)·r·m·ln(D/r)
where
Eo=critical disruptive voltage in kV to neutral
go=critical gradient in kV per cm (21.1 kV/cm, but Section 10 gives more accurate numbers and includes bundled conductors)
delta = air density = 17.9·b/(459+°/f)
b=barometric pressure in inches of Hg
r=conductor radius in cm
D=distance in cm between conductors for 1Ø or equivalent Ø spacing for 3Ø
m=surface factor (0.82 for stranded, 0.92 for segmental)
It also has corona loss curves for different conductor types.
Bill
"Why not the best?"
Jimmy Carter
Thanks jghrist. This would even work on bundled conductors.
Magoo2 most of the lines I work with are 345, 138 and 69kV.
And 138kV and 345kV lines do require multi-conductor bundles.
Mostly
2-795kcmil, 2-1590kcmil ACSR and 2-2500kcmil AAC
Thanks all for your valuable input.
delta = air density = 17.9·b/(459+°F)
