RS232 to Ethernet Convertor
I have a PLC with RS-232 output.  My customer does not want to use a laptop to download data from the PLC.  He wants to use ethernet connection and download remotely.  Are there RS-232 to ethernet convertors available for this kind of application?
RE: RS232 to Ethernet Convertor
There are a lot of serial server devices available, that convert RS-232 to ethernet.
Take a look at this page to get started.
http://www.digi.com/products/serialservers/
I have had good results with the Digi One.
There are a lot of other brands to choose from too.  Try a Google for "Serial Server".
B&B has industrial terminal servers that are DIN rail mountable and +24VDC.
http://www.bb-elec.com/
Lantronix also has a line of industrial terminal servers.
http://www.lantronix.com/solutions/industrial-device-networking.html
I have used these and the Digi, and they are all on a fairly even plane. I prefer the devices that are DIN rail mountable and +24 VDC because they can more easily integrate into the same cabinet as the PLC and use the same power supply
what plc are you using. Some plc's have the capabilities and some dont for the converter plugins
I have used the Lantronix units for several applications, PLC, Traffic Detection and Video Switch control. In all applications I have found them to be quite good, easy to set up and quite transparent. The applications have also been through remote dial up (I'm a dinasaur!) and worked seemlessly.
Mark Hutton
Do you have the model number of the unit?  All I need is one port on RS-232 DB-9 Male converted to ethernet.  I need to be able to assign IP address for the convertor.
This is the DIN rail mounted Lantronix terminal server. It has an RJ45 interface, but you can get a RJ45 to DB9 converter easily. This would be more in line with the industrial environment.
http://www.lantronix.com/device-networking/external-device-servers/xpress-dr_dr-iap.html
Here is a single port model
http://www.lantronix.com/device-networking/external-device-servers/uds1100.html
Try the Precidia iPocket, it is small, inexpensive, and works well.
http://www.bwi.com/search?search_token=ipocket
I second the digi one SP.  They have a serial port redirection software that works great for me even over a VPN connection.
