Plastic pipe in indoor chilled water systems
I am looking at using plastic pipe to distribute HVAC chilled water through a utility tunnel in a college campus application. What are the drawbacks in using plastic verses steel in a tunnel? What type of plastic pipe is commonly used in this application? The pressure will be relatively low (tallest buidling is 6 stories and the pump head will be less than 60psig.). Does anyone have a design guide for plastic pipe in chilled water applications?
RE: Plastic pipe in indoor chilled water systems
http:
Maybe look at urecon preinsulated pipe
Take the "V" out of HVAC and you are left with a HAC(k) job.
