Print on large format paper
I want to print a small spread sheet on large ANSI D size paper. This spread sheet will be posted on a wall and I need room to write in some of the cells... and have an audience be able to read it.
For a simplified example.. consider one cell with one word (Welcome)in it.. now I want to print this and fill a ANSI size of paper with this one word.
At some point in the page setup there is an option to scale. It seems the maximum is 400% but this is not enough for my needs and does not fill the page.
Does anyone have any ideas on how I might find something similar to "expand to page".
I expect that one round-about way to do this would be.. in my example... use the largest size of text available (72 point ?) and then scale it to a maximum... This would mess up the rest of the spread sheet which is "normal" and needs to stay that way so I would prefer not to go that route.
The other way would be to make my "sign" with a program like AutoCad or Solidworks... but then the secretary who is making this spread sheet would be out of the loop for changes etc..
Thanks for any thoughts
Ralph
RE: Print on large format paper
Make a PDF of the spreadsheet.  Then print that PDF to your large format paper, Acrobat reader has an option to expand to fill the page.
Alternately, if you don't have a way to create a PDF you can use the Microsoft Office Document Image Writer.  Just print as you normally would, but choose the Image Writer as the printer.  It will output a .TIF file that you can then print to whatever size you want.  If you don't have software installed that will handle TIFF images, you can use IrfanView.  It's freeware.
-handleman, CSWP (The new, easy test)
By the way, MJ, while the link you provided is fascinating, how does it relate to printing spreadsheets at a blown-up size?
Handleman,
Each cell is a pixel...
It doesn't really address the original question - although it does present an alternate for something simple like a "Welcome" page.
Thanks for all the thoughts.. I suspect by using the PDF approach the text will get very pixalated. We do this frequently with PDF drawings and find this to be a problem. Similar problems will likely occur by printing a tiff file. These are all esentially raster images and do not expand very well.
You should try the PDF approach. It doesn't save all text as a bitmap. It depends on the source and the program that's used for creating the PDF.  If your text is something common like Arial or Times New Roman, I think you'll find that it saves the Postscript representation in the PDF file.
Glenn
You could increase the size of the font, the row heights, and column widths with the Format command so that it is a readable size on ANSI D, then print to the plotter.
I use CAD to copy and paste the spreadsheet into a drawing (paperspace normally) and then I can plot it to whatever size paper I need.
Don Phillips
http://worthingtonengineering.com
Thanks again all.. Will try DonPhillips idea of pasting the spread sheet into AutoCad, see how that works
All the different PDF print drivers I have used create vector information not bit map information.  Comparing this to drawings scanned into PDF format is truly an apples to oranges comparison.
If you type in the text size box a number bigger then 72, you will have your text write in that dimension. I think the max character size that excel support is 409!!
if you want to keep the other part of your spreadsheet in normal dimension you can create a 'mirror sheet' formatted big.
as an example:
if you have relevant information in Sheet1!A1:D10
just type in sheet2 A1: =sheet1!a1
in sheet2 A2: =sheet1!a2
in sheet2 b1: =sheet2!b1
and so on
then you could format the sheet2 for big print and keep the sheet1 standard.
Maybe this can help!
Onda
