Inventor isometric views are NOT to scale
I was just recently informed that the isometrics that inventor inserts into it's drawings are not to scale. A quick measurement confirmed this to be so. Is there a way to ensure they come in at their proper scale?
RE: Inventor isometric views are NOT to scale
Inventor 2009 allows you to put on the true dimensions or the projected dimensions.
http://en.wikipedia.org/wiki/Isometric_projection
Isometric views are not projections of the true image because the sides are supposed to be equal length.
I would like to attain true isometric views from inventor not representations.
So if your base view scale is 1/2 (or .5) then make your isometric view scale .6125 (.5 x 1.225)
"in which the three coordinate axes appear equally foreshortened "
A di-metric projection keeps one axis with no foreshortening, and may be what you are looking for?
