Risa-Revit link
Risa-Revit link
Risa-Revit link
Just a question to ask if anyone has had good success with the round tripping of the Revit Risa Link, and are there any good tricks to make it work better.
I have used the link about a dozen times, but every time there is a lot to clean up, and I have always been frightened of the round  tripping.  It just has not worked for me.  I usually just go once one way or the other and not the full circle.
Is there any good, up to date tutorials on the link?
RE: Risa-Revit link
Hi Baw1,
Currently we have our documentation about the link which does describe each links features as well as tips on how to round trip.  You can get this at http://www.risatech.com/partner/download/RevitRISAComponent_2009.pdf
If you're seeing a lot of things to clean up when you translate the data, we'd appreciate knowing exactly what you're seeing.  We've tried to make sure 95% of the data goes back and forth with little to no clean up neccesary
Let us know if we can address any specific issues you might be having.
RogerAtRISA
