Applying Force signal in a point of a model using ANSYS Workbench
Could you please explain how to apply a time-varying loads in a single point of my part using ANSYS workbench?
Thank you in advance for any information you may give.
Best regards,
Chaabain
RE: Applying Force signal in a point of a model using ANSYS Workbench
simply select "Function" from the drop-down list associated to the "Value" of the force. Then write the function you want in the field.
See also Workbench Simulation Help file.
