copper corrosion protection
I am fairly familiar with the use of anodizing/alodining aluminum surfaces to prevent corrosion, but are there similar processes for copper? I have 110-alloy electrical grade copper shims which I would like to treat, and the coating should be RoHS-compliant. Thanks in advance.
RE: copper corrosion protection
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
There a kits available from my electrical supply houses that can do small silver plating jobs for testing.
Try this source i think that can give you some good advise, it's the best source on copper on the web:
http://w
h
hope this can help u
S.
Corrosion Prevention & Corrosion Control
