adding to existing fillet weld
I have a condition where a 1/4" fillet weld has already been made. Now, a 5/16" fillet weld is required. Is it acceptable to just ad the additional 1/16" of weld?
Thanks!
Thanks!
RE: adding to existing fillet weld
You don't say how thick your metal components are, but your fillet weld size cannot exceed the thickness of the smallest section within the joint.
desertfox
Yes, provided you add filler metal to make the existing fillet legs equal in size for a 5/16" weld.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
