I beam thickness
I beam thickness
I would like to know, what the thickness of the webs (vertical Part) of 4 I beams would have to be to support 200,000lbs. (near center-50ft. foot print) if the span is 150ft. long and the web is 30in. high with 10in. sole plates.
thank you.
thank you.
RE: I beam thickness
How your beams are supported.
How your load is mounted.
How your load is distributed.
What material you're using.
How thick the flanges are on your beams.
What if any local codes apply.
Whether there is any dynamic loading.
Whether there are additional loads (wind, snow, etc.).
What safety factor is required.
What the desired maximum deflection is.
How long you want the thing to last.
and so on, and so on.
That being said, its pretty basic engineeering that most structural or mechanical engineers would be glad to handle for an appropriate fee.
