Grounding Grid Placement
Is it necessary to place the Grounding Grid below the frost line of the soil to ensure the resistivity of the soil will remain constant and also to prevent heaving?
Thanks in Advance!
Thanks in Advance!
RE: Grounding Grid Placement
The grounding grid, however, should probably be relatively close to the surface to provide adequate step/touch potential reduction. The frozen soil has a very high resistance.
