Weld Symbols
Weld Symbols
Weld Symbols
I am trying to place a weld symbol in a drawing (I need to specify a braze, though).  In the help section (in topic "Weld Symbol" under "Arrow Side/Other Side") it states the following:
"...Brazing     Specifies whether the weld is brazed. Select or clear the check box to add or remove the brazing symbol.
Clearance
Specifies the clearance for the braze."
Am I missing something?  I do not see any Brazing check box.  Can anyone tell me where or how I can access this feature?
Air cooled, belt fed, gas operated machine gun firing from the open-bolt position
