extremely light duty flanges
Is there a standard for light duty flanges?
We only have about 1 psi pressure and we're using sheet metal parts to confine the fluid.  We would like to find a standard size light duty flange to use for our connections.  Specifically, we're looking for 5" & 6".  Everything I've found so far is 125# and higher.
Please let me know if there's anything lighter.
Thank you.
pesy
RE: extremely light duty flanges
There are class 75 flanges per ANSI B16.47, Series B (Old API-605).  Unfortunately, this standard only covers sizes 26"-60".
I think the normal practice is to use a plate flange with full face rubber gasket that is 150# ANSI B16.5 drilling, but thinner.  Determining the minimum required flange thickness is not a trivial matter.
