pv elite
pv elite
hi friends
I am working with pv elite to design pressure vessels. Can someone refer me some good websites from where i can get examples to use this software?
thanks
thanks
RE: pv elite
gutej,
Within the past year I had a similar quest that proved fruitless. coade.com was all that I could find, unfortunately the online help for pvelite is not at the level as caeser2 (which I found very helpfull).
Coade does have a discussion board for pressure vessels
http://www.coade.com/support_discussion.asp
which might help you.
RE: pv elite
RE: pv elite
RE: pv elite
In addition, there is a quick start guide that can be accessed from under the Help menu of PV Elite.
There is also a tutorial in user guide.
RCHandy, thanks for the comment about CAESAR II. They will get encouragement out of it.
RE: pv elite
I tried that quick guide. The example in that is quite simple but the vessel i am working on is quite different in terms of construction. I think i have to do more research on this and have to sit late nights sweating on my chair.
Gurtej
