Moment of inertia measurement
I need to measure, not calculate the moment of inertia of a spinning object used in experiments. MI keeps on changing as parts are added moved or taken away from experiment to experiment. Are there any products out there which can do it quickly and easily?
Size is around 75 - 150 mm diameter (3-6"), MI 0.0001 Kg m sqr (0.34 pound square inch)
RE: Moment of inertia measurement
http:
Ted
http://fa
If you can, you could take the spinning inertia and supporting it at a shaft end you let it "gyroscope" getting the precessional RPM and then, by Newton
Torque = time rate of change of angular momentum
T=Im*w
Im= angular momentum of spinning mass
w= measured precessional speed
T= W * arm
