IRC Rafter Requirements
Does anyone understand the rational behind the Rafter Span Adjustment Factor given in Note a of IRC 2000 Tables R802.5.1(1) thru R802.5.1(8)? Is this a strength reduction consideration when a rafter tie is placed in the rafter space rather than at the top of wall? A FEA model of the situation I did seems to indicate that the rafter strength is actually increased when adding a rafter tie in the rafter space above the top of wall. Or is this requirement there to protect the walls from the outward push force as there is still some outward push (albeit considerably less than with no rafter tie at all) when using a rafter tie above the top of wall height? If this is the case, how is this accomplished by reducing the allowable rafter span for a given size and spacing of the rafter?
RE: IRC Rafter Requirements
Carl Bauer
www.bauerconsultbotswana.com
Does that make it clear?
Here's a link for more info on the WFCM:
http://www.awc.org/Standards/wfcm.html
HTH
