Effectiveness of Steel sealant on corrosion
Hi all,
I would like to ask if steel sealant can prevent corrosion from Steel reinforced cement  entirely.
I understand the two major factors of corrosion is the effect of chloride and/or Carbonation.
I want to know if steel sealant can prevent corrosion caused by the two factors.
thank you
