AS1554.3 Welding of Reinforcing Steel
I understand that welding of reinforcing is to be avoided but looking through AS1554 there doesn't seem to be anything overly prohibitive there?
Am I correct in saying that if class N reinforcing is welded in accordance with Table 3.2 (ie W50X) no reduction in strength is required? Or are some intensive testing proceedures required?
I have only used welded reinforcing for cast-in-plates, tags etc..and adopted a 250 MPa yield stress for class N reo that has been hit with a weld, due to inhouse direction. Is this too conservative?
Thanks!
Thanks!
RE: AS1554.3 Welding of Reinforcing Steel
I don't think your inhouse direction is too conservative.
I am still confused by the fact that AS1554.3 has no statement about using a reduced yield stress for affected reinforcing. This leads me to believe that if the correct welding equipment is specified no reduction in fy is required. I have also read elsewhere in this forum about the American code permitting welding for specific reinforcing grades and equipment - but i don't know how this correlates to true blue steel.
If a reduction of fy is required for welded reinforcing can you direct me to any reference material that has the design requirements?
Other than poor welding practice, the other problem is embrittlement of large bars where small crossing bars are tack welded.
If welding to a plate you will be limited by the plate strength which will be 350 MPa at best.
So is 'properly' merely defined by the welding material as per AS1554 or is a more rigid specification required (again just for shop fabricated components)?
Thanks.
This document provides information on welding of 500PLUS Rebar. Procedure for specific weld types with advice on electrode types, weld length etc. is also included.
ht
Have you seen a similar document for standard N grade reinforcing?
Further to welding of N grade reinforcing bar, I was after clarification of allowable field bending and heating of reinforcing and subsequent reductions of capacities.
http://www.eng-tips.com/viewthread.cfm?qid=207584 has links to document that in summary states that:
Bars up to N16 can be cold bent (once) without reduction in yield strength (N16 have 5% reduction)
Bars above N16 can be bent once heated (within specified heat range) with a reduction of only 10% of yield capacity.
I was pretty surprised by the relatively minor reduction in capacities given the taboo mindset of heating reinforcing on site.
So:
Are these figures appropriate for N grade reinforcing?
What is the significance of the elongation reduction? Loss of ductility?
How can the specified heat ranges be enforced/monitored?
Is there a 'heating of reinforcing for dummies' document that could be given to a builder?
What would be appropriate capacity reductions for a bar that has been hot bent without not in accordance with these specifications (just a big mug with a gas torch)?
I understand that heating reinforcing should be avoided but I still wish to understand this for:
Assessment of the capacity of reinforcing that has already been heated and bent.
Guidelines that can be provided to site for critical applications (for heating and bending).
Many thanks!
Basically;
- cold bend around min. dia. pin as specified in code
- hot bend, OK if < 450 deg, reducing to 250 MPa yield if temp is > 450 deg & less than max. of 600 deg.
- Do not bend in same location more than twice.
Further info can be found here;
http://
