Minimum Allowable Temperature considering flanges
If a vessel has flanges made to ASME B16.5, does that limit the Minimum Allowable Temperature (mat) to -20 F regardless of the temperature reduction credit provided by Figure UCS 66.1? For example, if a vessel has an MDMT at 32 F but operates below its design pressure such that a temperature reduction of 60 F is allowed (mat=32-60=-38F). Would the mat have to be limited to -20F instead?
RE: Minimum Allowable Temperature considering flanges
