solidworks feature question
i have created a circular array of a steel rod base for a side  table. i used the curve pattern feature but once i have filled all the appropriate fields and checked the correct boxes and pressed ok, all of the pieces in the pattern disappear (except the source feature).  how can i correct this? it isn't an assembly or a 3d sketch. am i missing something?
RE: solidworks feature question
Are you sure you really want to post a purely solidworks question in the Industrial Engine forum?  The Solidworks forum might be better
David
