Look-up-table in the Microchip PIC 16F84
I would like to program some sort of a look up table for the 16F84 PIC microcontroller.
Does anybody has an example of how it’s done and if it can be  done period.
It should work like this: …..
when count is 125 -> var…->var 2 is…etc.
when count is 126-> var1…->var2…..etc.
and this for 0 till 150.
RE: Look-up-table in the Microchip PIC 16F84
Use the value as an offest into the table.  I.e, base table address =1000h, and table length is 150.  Store base address into a register, add the register plus offset, and do a register indirect read / write to / from memory.  There is a more dangerous / tricky way, but I would not suggest doing it unless you absolutely need to!
Good Luck and keep us posted!
      CALL     TABLE ; W REG must allready contain talbe offset
      .              ; W reg will now have table value
TABLE  ADDWF PC       ;W = offset
       RETLW k1       ; first table value
       RETLW k2       ; second table value
       RETLW kn        ; last table value
Thanks all, you’ll be hearing from me if it all works out!
Hi Spiraal,
There is a problem with call up tables on all pics and that is if the table is in a different bank to the program call, the program will crash
I have used the following code with several very large tables in the same program without problems and I now use it as a standard.
         clrf    pclath
         movf    number,w ; program will jump to number
         addwf   pcl,f
          retlw     000 ; number = 0
          retlw     100 ; number = 1
          retlw     200 ; number = 2
          etc etc
Good luck,
G
