Composite Beam w/Formed Steel deck
According to AISC 9th edition (ASD) section "I5" concrete below the top of the steel deck shall be neglected when determining section properties and in calculating "Ac" for Equation (I4-1).However, the manual is not clear about the location of the concrete NA. In other words, is the rib height ignored or used in determining the "NA" and "I" of the composite beam.
Thank you
Thank you
RE: Composite Beam w/Formed Steel deck
