dft_to_dwg
dft_to_dwg
Hello
Anyone try to convert big dft file to dwg with se v20 ?
For ex. I have a dft file aprox 30MB i converted the file to Autocad but I can not open the file in autocad.
I did the same operation with the same drawind with se v18 and was working.
Please if you have some ideas give a replay.
A good day!
A good day!
RE: dft_to_dwg
Please have anybody meet this converting problem from above with se 20?
a good day everyone!
RE: dft_to_dwg
Are your settings the same as when you converted in V18?
Have you tried a smaller file dft ?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
RE: dft_to_dwg
yes smaller drawings are working ok but 30 Mb no.
RE: dft_to_dwg
Try copying the drawing and delete some of it - 1 or 2 views - (from the copy!!) then try converting.
Is it a multisheet drawing ?
bc.
Quadro FX4600.
RE: dft_to_dwg
I think the problem is the size of the drawing i try to convert also 20 Mb and is the same problem but with 3-4 mb drawings is working fine .
as i mentionate before with se 18 30 mb was no problem to convert to dwg
A good day everyone
RE: dft_to_dwg
beachcomber did you try sometimes to convert a dft file more than 20 Mb to dwg and was working with se 20 ?
Agood day !
RE: dft_to_dwg
Try it on a free Dwg/Dxf viewer.
RE: dft_to_dwg
However, it's just as well to check, so what version are you saving as, and what is your ACad version ?
Yes, I think I have converted files of that size from V20.
Is it doing the conversion from SE, or is that the part that's failing ?
As Alan says, if you get the ACad file you can view it with the SE Viewer.
bc.
Quadro FX4600.
RE: dft_to_dwg
RE: dft_to_dwg
I'm converting to AutoCAD 2000 and I have 2008 looks like the same problem like fun4 said it creates the dwg file but I can not open it with AutoCAD , but with a dwg viewer is opening and looks ok , I need also to edit the dwg file not only to create it.Maybe with another sp will be ok .
A good day everyone !!!
RE: dft_to_dwg
i think is a problem with .ini file in se 20 with his own secad.ini file is not working but with another .ini file was working but with some small mistakes.
all the best
