Square hollow column buckling
I have been trying to figure this out for a while and am having a problem with putting this together. Here is the setup. I have a long square hollow beam (L=2m, h=w=0.3m, t(wall)=0.5in), capped of on both side with the same thickness plates. Its loaded in compression as well as there is a force at the center of each side on all four faces. So it is loaded from all sides. I am not sure what is the best way to analyze it for buckling, since that is what I am worried about. It is not a simple Euler problem since in addition to the axial loading you have side loads from each side, which deflect all sides of the beam inwards. Any assistance would be appreciated.
I am attaching a pic for clarification.
http:/ /files.eng ineering.c om/getfile .aspx?fold er=76bd6f5 d-085a-4d2 b-89e8-690 2d625a287& amp;file=l oading.jpg
http:/
RE: Square hollow column buckling
1. Determine resultant load from all four directions. This will give you a load at some angle (let's say theta) perpendicular to your cross-section.
2. Find the geometric properties with an axis that has at least one axis perpendicular to that applied load.
3. Solve as either Euler or Johnson-Euler depending on if it is considered long/short column (This is important).
4. If loads are variable, then come up with a spreadsheet or mathcad (tm) sheet that will account for that.
5. Profit.
:) Good Luck.
Nert
Euler and J-E are not beam-columns,which is what you have.
What you have is a beam-column. So you will need to use Beam-Column equations.
However, Steps 1&2 are still applicable. Then, find a beam-column equation for a point load (where the resultant is) and the axial load that you have.
Good luck.
Nert
Are the 4 loads symmetrical? are they small in comparison to the axial load?
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Then, if you are worried about the "squishing", then I would think you can do (conservatively) the following:
Assuming that the applied loads are not on the "corners" of the square, but rather somewhere between them, then try the following:
1. Calculate the maximum deflection (delta) of a simply-supported beam of length = to one of the sides (.3 mm) with a point load somewhere along the length (where your side loads are applied).
2. Assume that the "square" shrinks the amount of "delta" for each "leg" of the square. I would think that you can then whip up an "artificial" geometric properties of the "deformed" section and run a beam column equation.
Nert
If the four loads of 48kN are all directly opposite then you don't have a bending load over the 2m length of the beam,what you do have is local bending on each side of the tube ie:- over the 0.3m length.
Then the axial loads you have make the tube act like a strut.
Slight correction:- you do have bending over the 2m length
of the the tube but due to the tubes own mass and not from the external loads.
what inertia4u is trying to say is do the beam calculation over the length of the 0.3m (width of box section) using the thickness of 0.5" as the depth of beam to check for local bending.
I would do the following determine deflection of the tube as a beam column using the beams weight as the transverse load for bending.
I would then check for local deflection or buckling across the width of the beam as suggested by inertia4u.
regards
desertfox
I spent a little time this morning drawing up what I was talking about (a picture is worth a thousand words). If you can't view excel, I'll see if I can convert it to another format.
Cheers,
Nert
http:/
Nert
When you do your final column check - verify if you are in long column or short column range. If you are in the short column range, then you will be limited to either the crippling of the tube (Fcc) or Fcy of the material. I say cripping only because you have 4 corners on the square tube.
Peace
Nert
Let me clarify, once again :)
If you have a short column, you will use Johnson-Euler equation. The limiting term will be either Fcc or Fcy in the J-E equation.
Nert
A couple of other things that I've been thinking about and rereading some of the responses here.
You may want to account for weight as pointed out by desertfox - (us aero guys typically don't do this because our stuff is so darn small, relatively speaking).
In the final step of that excel file I posted, you may need to account for the deflection of the beam under its own weight, which will introduce eccentric loading into the column, thus turning it into once again a "beam-column" (we can't just seem to get away from that!!) - the equation that comes to mind is typically called the "secant formula for beam columns" (see the link below) and will allow you to calculate the maximum stress in the beam.
Nert
Why not just workout the deflection in bending due to the weight of the beam, then use this formula that inertia4u posted in the link. the offset for the applied axial load can be the beam deflection.
The other local bending calculation can be done afterwards to see if the tube wall will collaspse.
http://w
regards
desertfox
This is by no means a simple problem, for sure - but it is very interesting.
I'm not sure I quite follow your 16:29 post - but if you are saying what I think you are saying, I would not advise neglecting the axial loads for determining the deflection of the wall. As desertfox noted, the deflection for the beam-column is on that efunda website link (look for the boxed equation).
A beam-column is essentially a column problem where the transverse load actually subjects your column to a bending moment. This bending will ALWAYS cause your column to fail before it can reach the pure column buckling load because of the eccentricity of the load path.
Note that the secant formula only gives you max stress, it will not tell you if the section is stable or not. You will have to locate a reference which will show you how to write a safety margin for the interaction of the "bending moment" and the "column allowable."
If you are going to be working a lot of these kinds of problems, I would recommend you find a good reference book which contains tables for beam-columns, deflections and how to calculate safety margins.
For my work, I use "Engineering Column Analysis, The Analysis of Compression Members" by William F. McCombs. He covers a lot of the different types of columns/ beam-columns, stepped columns, buckling crippling yadda yadda. The data and equations, I believe should be applicable for all Engineers, regardless of background
[In fact, when I went to a website that sells it, it is listed as a Civil Engineers book, although McCombs is more known in the Aero industry]
This book really is nothing more than a photocopy of work that Mr. McCombs finished before passing away several years ago. It isn't pretty, but it contains a ton of *USEFUL* information that you can reference in your stress notes.
If you are still having trouble, then I would recommend maybe hitting a technical library. I've actually had http://www.lindahall.org/ email me articles dealing with problems I'm working ( at a price :) ).
I sincerely wish you luck!
PS: The link below is where I bought my copy of McCombs book from. Please note that is is totally soft cover (in fact, the cover sheet is nothing more than a yellow piece of paper!)
Nert
I do not think you will have an overall buckling with those dimensions on the column. However, you will have some local bending problems on four side of the column if the loads are directly go to the centers of the column webs by an web side plate. Using a web side plate with longer contact length with column web may reduce the problem, however does not eliminate the bending on the web.
I do not know how and what introduces the side loads onto the faces of the column. There may be a stability problem of the square cross section under four side loads as well. In case one of the connections introduces lateral bending the cross section mat have tendency to get into a diamond shape ultimately flatten if there is no other restraint. Therefore in the large column sizes there are always one or two levels of internal diaphragm plates used to eliminate this kind of instability.
If you can transfer the loads from each side to the two side webs, the webs are not going to be under local bending and this might be another way to solve the instability by using connected beam stiffnesses at the connections.
Hope it helps,
Ibrahim Demir
- does the load stay the same as the deflection increases? (gravity-type loading)
- does the load reduce as the deflection increases? (spring-type loading)
Knowing this, I can also attempt to evaluate how much the side loads act as a brace point for my overall column buckling.
One other thing that I find lacking from the replies is the question of how much of the wall will contribute to resisting those lateral loads? inertia4u's spreadsheet is nice, but it doesn't mention this at all.
If this problem was on the borderline, a good FEA model may have been in order.
For the problem at hand, however, I think your walls are in trouble. If you assume that 16 times the thickness of your plate wall contributes to resisting the side loads, we get an 8" width. Using this and the 1/2" thickness, the moment of inertia for the section is 0.0833in^4 and the applied moment is about 31,900inlb which gives a max stress of over 95ksi. This does not consider the axial load from the two opposing walls, nor the axial stresses from the 137kN in the other direction. Unless this is a pretty exotic material, it's just not happening...
A possible solution: beef up the central section to resist the center wall stresses by either making the local portion much thicker, or installing a central plate for these loads to pass through. Once that problem is solved, if this is steel, there are no buckling issues (local or overall) with the assembly by my estimation. The axial stresses (from the 137kN load) are a good deal less than 2ksi and this is a pretty stocky column as has been mentioned.
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
This is why I still firmly believe that it is good to have another set of eyes looking at a problem.
searingen,
I thought my buckling check of the walls did "resisting those lateral loads" as you say.
In other words, if the walls do not buckle, (bending + axial, beam column), then the section can be considered stable and the critical wall buckling load becomes Johnson-Euler (which limits the section to Fcy) - or maybe even a flat plate buckling - ss on all sides. What am I missing?
Cheers,
Nert
Nert
look at a slice of one face, the pressure load is reacted on the sides. the sides load up each other (in compression by the sound of it) so that each face is reacting the pressure as a beam (or a flat plate) and each side has a compression load from the adjacent sides. i think it's reasonable to say that the pressure load is reacted on two sides, that the shear load in the sides is reasonably constant along the length of the column.
I guess you need an engineer to do the job for you. Obtaining information without a proper background can make you disappointed in the end.
From the beginning we are trying to solve puzzles, every puzzle brings another one. I suggest you to consult a structural/mechanical engineer to solve your problem by presenting all the details you have to consider.
Hope it helps.
Ibrahim Demir
Cheers
Greg Locock
are you welding this strut together ?
http://www
Regardless, it looks like there may be enough information provided now to get a better understanding of what you have, and at least get a better FBD developed!
Good luck!
Nert
If we take a 1" wide strip of the wall, it would have a distributed load of 13.7lb/in. The moment becomes approximately 13.7*11.8^2/8 = 239inlb. Using my previously calculated moment of inertia, this gives a stress due to local bending of 0.7ksi - much more manageable. Add to this a local axial stress on our strip of 13.7*10/2/(1*1/2) = 0.14ksi and I don't think you'll have any local beam-column buckling of the wall. Again, since your global column axial stress is less than 2ksi as stated in my last post, it appears this column is just fine - unless, of course, you pull another odd constraint out of your hat...
i'd be more interested in the analysis that showed it "marginal". possibly the problem was that you can't (shouldn't) separate the loading on one face from the other (faces), and once you have that thought out you see these loads are self-reacting.
still like to know how you get magnetic loads on an Aluminium structure ...
You guys did help me a whole lot and just the discussion brought a lot of good points which is what I was looking for. Can anybody recommend any other books in addition to Roarks which have additional solution to plate/beam problems, since I have couple of cases which are not present in Roarks?
Nert
ASME Sect VIII Div 1 - Appx 13 - Section on the design of "Vessels of Non-circular Cross Section".
Ibrahim Demir
