ANSI Y14.5-1994 interpretation
What is the meaning of "MR"?
It used to be Full Rad then added CR for Controlled Radius.
I have a customer who dimensioned a radius MR
RE: ANSI Y14.5-1994 interpretation
Radius dimensions were either R or MOD R.
R was like a controled radius, no flats or reversals.
MOD R allowed flats and reversals.
It may be this is what the customer means by MR, you better ask to be sure.
Peter Stockhausen
Pollak Switching Products
And it's "ASME Y14.5-1994".
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Jul 13, 2008)
I don't see it listed in Fig C-3 or section 1.8 of ASME Y14.5M-1994 and don't recall ever coming across it.
I even checked Y14.38-1999 and while it has 3 options for what MR can be, none of them are relevant (Machine Rifle, Maintenance & Repair, Marble).
I can think of at least 3 things it could be meant to be, Max Radius, Min Radius or Multiple Radii - guessing the wrong one might be problematic.
Again, ask the customer.
KENAT, probably the least qualified checker you'll ever meet...
To the OP if your customer print says ANSI Y14.5-1994 then it's referring to a different (non existent?) spec.
If it doesn't refer to ASME Y14.5M-1994 then you can't necessarily expect an answer to come from there.
It's Friday.....
Chris
AutoCAD 06/08
