Custom Lisp program needed
I am looking for a lisp program for Autocad that will extract attribute information from blocks and export the data direct to an excel sheet. The attributed blocks are usually nested deep within the drawing
This routine will require specific functionality per our Engineering needs and specification, so a generic program may not be good enough.
Not sure if I can ask for programming help on this forum, but I am looking for a custom lisp programmer that is experienced with this type of programming. If someone can offer any help or suggest a contact, I would greatly appreciate it.
Tom
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Premium 2008 SP 3.1 & PDMWorks
RE: Custom Lisp program needed
You might try the sister site to this one - Tek-Tips.com
Have you tried Eattext (or Dataextraction)? Try it, you may find you don't need a custom routine.
____________________
Civil 3D 2008, Terramodel
