supercritical CO2 injection
I need information for references and suggestions for compressor or pump vendors that would be capable for injecting supercritical CO2 550 bar. It seems that alot of vendors are hesitant at that high of pressure. The need for the 550 bar pressure is due to the reservoir.
RE: supercritical CO2 injection
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
In the LDPE they used hyper compressors (google for vendors). to ethylene to 30,000 psi. Ethylene acts a lot like CO2.
http://www.dresser-rand.com/recip/default.asp
Nuovo Pignone is the only company that would give us a quote for the CO2 pumps. I was looking for other companies that may exist that i didn't know about that would be able to quote to give us more than one option.
The highest that the centrifugal compressor manufacturers will quote for is 200 bar.
Also through all my internet searching i haven't found any CO2 references for pumping at these pressures. I would really like to get some background on prior implementation of this design especially if i'm limited to only one vendor.
