about the rotation direction of dana axle
our company bought two dana axle, but I find the rotation direction of axle is  different from the Conventional vehicle axle.
  I attached a drawing and you can find the position of final reduction gear is not like Conventional vehicle axle's.
  anybody has this experience?
RE: about the rotation direction of dana axle
What is your definition of "conventional" axle?  What type of final reduction is your frame of reference?
rmw
thank you,rmw
as Conventional vehicle axle, we face to the input flange of rear axle,when the input is clockwise so the vehicle go forward.
    but dana axle is On the contrary.
Flop the crown wheel over to the other side of the pinion.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
This axle could have been for a rear engine drive vehicle like a bus is.  But the solution presented by pat will solve it for you.
rmw
thank you! pat  rmw
