Residential load calculations
Can anyone recommend a good step by step book/manual/guidance of residential wood structural calculations and the design process? (Wall PLF, footings, headers, shear walls, force on connections.
I'm looking for something that has a ton of example problems.  I'm wondering if something like this exists.
RE: Residential load calculations
APAwood has some good stuff on plywood w/ examples.
IBC2006 has some info - esp to meet code
You might Google on "Residentail Design".  There are some good books on the subject.  Sorry can't remeber the titles.
Started with new company that bears steel beams on wood posts is that per code (IRC)?
Steel beams are not covered by the prescriptive IRC code, therefore require to be engineered.
Once designed, the beam can be supported on anything capable of  carrying the applied loading.  A properly connected, sized, and braced wood column can be used to support a steel beam.
That is acceptable if the wood column can carry the loads.
I usually recommend it in wood framed houses because the column and walls will shrink/grow at the same rate.  If you have a steel column in a wood frmaed wall - the column will NEVER change lengths (except for temp extremes) whereas the new wood framing will likely shrink at first and then shrink/grow as the humidity changes from season to season.
Cuts down on drywall cracks....
Thanks for the updates everyone!
