PDA (Case Method)
PDA (Case Method)
Why is the resultant divided 2(R/2)when the downward compression way meets the shaft friction? Why is it not some other ratio which would be dependent on the value of the upward friction?
RE: PDA (Case Method)
one thing to point out is that you can have higher tension forces say if you have hard driving passing through a hard layer in to a very soft layer. you could also have high stresses for hard toe conditions. i believe the theory says you could approach 2x the input at the toe for the hard toe condition with no/minimal side friction.
Conversely, for a free toe, you reflect a tension wave, which is why tension cracking has to be monitored during the early stages of pile driving for concrete piles.
A quick program which is good to illustrate this and many other aspects of wave propagation is the Pilewave program, which can be downloaded from
http://www.piletest.com
http://www.vulcanhammer.net
http://www.vulcanhammer.info
Fix end - compression 2x top force
Free end- high tension
Infinit pile-no return wave
http://www.vulcanhammer.info/drivability/isa.php
In practical applications, the numerical solutions are necessary.
That includes the FHWA manual on driven piles, which is a good starting reference.
