Geothermal Heat Exchanger
I'm researching Geothermal Heating energy and I am curious as to why hundreds to thousands of feet of coiled Polyethylene piping is preferred over perhaps a buried aluminum heat exchanger. Aluminum has great corrosion resistance (unlike copper) and thermal conductivity. In my opinion, using a well designed aluminum exchanger drastically reduces the size of the excavation needed to bury so much pipe (in a horizontally laid system), which should offset any material price increase by using a metal over a polymer. Your comments are appreciated.
Also, I'm wondering if anyone is familiar with a more passive geothermal heat exchange, using the temperature gradient in the pipeline to drive fluid motion (slowly) rather than constantly pumping the fluid. I'm sure it works somewhat in theory, but I haven't seen practical use.
Aaron A. Spearin
ASQ CSSBB
Engineering Six-S'$
www.Engineering6ss.com
"The only constant in life is change." -Bruce Lee
RE: Geothermal Heat Exchanger
How much buried aluminum pipe have you seen? How many houses have aluminum water pipe, even as components?
Aluminum's corrosion resistance is not good enough for either situation. Plus, it is likely to dent and crack when backfilled, unlike a flexible polymer.
Although I have not run the numbers, I doubt the difference in thermal conductivity would give much benefit, the bigger issue is getting a large enough heat sink to balance the required heating/cooling load, i.e. getting enough cubic yards of dirt involved in the conduction process.
My university project (many years ago) was on geothermal downhole heat exchangers, where we used the heat gradient to drive the fluid flow. You get less heat out than by pumping, and there is a balance between the two which determines which is the better system.
By "corrosion resistance" I was considering only open-to air oxidation when comparing to copper... not considering contact with other fluids or interactions with earth minerals. My mistake.
Thanks for the info on your university project as well.
Aaron A. Spearin
ASQ CSSBB
Engineering Six-S'$
Luck is a difficult thing to verify and therefore should be tested often. - Me
1/U = 1/h_in + 1/h_wall + 1/h_out
Increasing h_wall won't do much if h_out is tiny.
Precisely...the primary source of resistance is the ground itself.
