Duplex Stainless Steel Pickling after Welding
Does anyone have any information on where I can find specific information about pickling vs not pickling 2205 duplex after welding?
RE: Duplex Stainless Steel Pickling after Welding
There is a similar document available on the Outokumpu web site.
Depending on the shield gases that you use in welding, the un-pickled welds can range from only a little worse to very bad.
Plymouth Tube
