alternate words for "obviate"
Anyone have a suggestion for an alternate word (phrase) to "obviate"?
As in, "once you start cutting holes in, or otherwise modifying, standard ASME B16.5 blind flanges the standard pressure-temperature ratings are obviated"?
RE: alternate words for "obviate"
But I'm still interested in an alternate word for obviate.
In your usage, it would seem that you're using the "render unnecessary" definition... sort of... more like "render inapplicable". Synonyms for obviate (as render unnecesary) would be preclude or make redundant... but that's probably not what you're trying to say.
Sounds like you're saying that you can add a nozzle without changing the rating of the blind. Possible synonyms:
affecting
changing
impacting
altering
modifying
If you're trying to indicate that a rating becomes inapplicable with some modifications, but not with this one, then perhaps the following would work:
nullifying
voiding
invalidating
Regarding obviate, how about circumvent
- Steve
- Steve
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Why the desire to remove 'obviating'? Seems like a perfectly good word to me, are you a victim of the clear English campaign or similar?
KENAT, probably the least qualified checker you'll ever meet...
It is probably not the best word to use for the target audience.
Prevent, Prohibit, Forbid; save, help, keep from; Deter, discourage, divert, keep off, ward off, stave off, fend off, fend, repel, deflect, turn aside; forestall, foreclose; preclude, exclude, debar, OBVIATE, anticipate, remove, dispose of, rule out.
Take your pick as to what seems appropriate.
Mike McCann
MMC Engineering
"not applicable" is my suggestion.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
By modifying them, you invalidate that guarantee.
You aren't exactly making that guarantee irrelevant.
GET ROUND;CLEAR AWAY...
