Electricity/Wire transfer to Copper
I have a wire to be soldered into a copper piece. The wire is rated at peak current of 1300 A (peak voltage is 880V). I am interested in how hot the copper piece will get from the current running through the wire, so I can determine the cross section I need to make the copper piece (it will be "T" shaped, with the wire going in one direction, and the other direction being a plug to transfer the current).
I have a few possible methods, though there are others I'm sure I haven't though of.
One I found in Mark's Handbook:
R1 = R2 (1+ alpha*T)
Where R1 is the resistance of the copper piece, R2 is the resistance of the wire, alpha is the temperature coefficient of copper, and T is the difference in temperature.
Resistance of the copper piecce is determined by rho*L/A, where rho is resistivity, L is length, A is cross-sectional area.
Another method I have though of is using conduction. Using the resistivity of the wire, and the current, I found power using i^2*R. Then using this as energy (W), I plugged into the equation
q = k*A*(delta T/L)
where q is Watts, k is thermal conductivity of copper, A is cross-sectional area, delta T is temp. difference, and L is length of the part.
Trying both, the delta T seems to be between 50-70 K, which when I convert to Celsius to check seems very high! Granted this could be due to using too small of a cross sectional area (say 8mm outside diameter and 3 mm inside diameter); however, I thought I would check with you all first.
Any input would be greatly appreciated. Thank you.
q = k*A*(delta T/L)
RE: Electricity/Wire transfer to Copper
Delta T = J/(rho*V*Cu)
where J is Joules, rho is density, V is volume, and Cu is specific heat (J*K/kg).
I am not familiar with this equation, though. Is this one more reasonable?
Merely works for one material, and explains how the material's resistance differs depending on temperature gradient...so that one is out.
TTFN
