Disable context sensitive right-click menu
NX 4 and NX 5
I am curious if there is a way to disable the context sensitive right-click menus.
My problem resides when I am zoomed in tight on an object, there is no 'open' screen available to be able to right-click and access the 'pan, zoom, rotate, and fit' commands. This forces me to go else where for the view related functions which have always been available in the right-click menu in previous versions regardless what type of object you are over.
Thanks in advance for your suggestions.
RE: Disable context sensitive right-click menu
Best regards
Simon (NX4.0.4.2 MP4 - TCEng 9.1.3.6.c)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but rather how many times it's taken away...
Best regards
www.jcb.com
