2 DX FCU from 1 ACCU
Anyone have experience with serving multiple DX FCU with one ACCU? This is for cooling of 2 offices and 1 conference room. The conference room has limited hours of operation, and not at same time as offices in general, therefore, it would get its own mini-split system. The 2 offices are on either side of the conference room. Time of use of offices are not necessarily the same, nor is the load.
Should I bite the cost bullet and just get 3 mini split, or is it likely that the 2 offices can be served well by one ACCU? Distance between office FCUs would be about 30 feet.
Thanks in advance.
Thanks in advance.
RE: 2 DX FCU from 1 ACCU
I've been to many meetings where the make shift system did not work :(
In meeting rooms and others with high occupancy, care must be taken in the selection of the system size in order to cater for heating/cooling the incoming fresh air, which may or may not be centrally treated.
