Discharging into full inspection chamber / manhole.
Has anyone come across what effect discharging a full bore pipe into an already full (of rainwater) inspection chamber has on the discharge rate.
Im assuming it depends on the size of the inspection chamber, how deep the pipe is submerged and what the head of water is driving the pipe.
Any help appreciated.
Kind Regards
Lee
Kind Regards
Lee
RE: Discharging into full inspection chamber / manhole.
I have not failed. I've just found 10,000 ways that won't work."-Edison "If Edison had a needle to find in a haystack, he would proceed at once to examine straw after straw until he found the object of his search. I was a sorry witness of such doings, knowing that a little theory and calculation would have saved 90% of his work.- Tesla
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
Is there a way to measure how soon the water will start to back up to roof level, therefore risking water ingress to the building?
Would that happen or would the pressure of the water force the underground drains to run at a higher velocity?
Lee
Katmar Software
