flat fins plate cooling coil VS corrugated fins plate cooling coil
I am doing a study on the above mentioned type coils. Can anyone help to explain thier heat transfer principles and which as a higer moisture removal rate, cooling air rate compare at the same velocity, cost, geomertic differences and etc.
If you have any articles or website which I can refer to is much appreactied.
