C-arm retrofit - camera replacement
I am purchasing a used fluoroscopic c-arm (GE OEC 9400). The problem is the system does not record images at a sufficient frame rate for my application. I would like to replace the existing c-arm camera with a faster one. My impression is that I just need to create a mount for the camera and fit the image intensifier output window with a macro lens.
Does anyone have a feel for what would be involved in this "retrofit" process? Will the existing circuitry be a problem?
I appreciate your help!
