Mistake Proofing.
Mistake Proofing.
I work in aerospace industry. Obviously we do A LOT of drilling and riveting. My question is that we have a high reject rate for Counter sinks being the incorrect size. Are there any tools/devisces that would mistake proof the drill bit(s) to where it would virtually impossible to drill a bad "countersink"?
RE: Mistake Proofing.
Are these holes being done with a hand drill or a drill press type setup?
A drill press can easily be setup to only drill to a certain depth. Set that and your Csinks will all be the same.
A hand drill/movable unit you can maybe setup a collar that would only allow the bit to go so deep.
Maybe something like the Jack Rabbit.
http://www
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
in other words it's adjustable.
I have been out of thr loop in aircraft assy , so i do not remember who mfgs it.
but it should give you a lead.
I will google it if I find it i will post it.
Let me know if this makes sense.
http://www.tooled-up.com/Product.asp?PID=32639
Ted
http
http://www.yardstore.com/browse.cfm/2,333.html
