Feature tree not updating with hole wizard change
Have a part with metric holes in it.
Edit all of them and make them english holes.
Save it and reopen it and the holes are still labeled in the feature tree as being metric (but edit the feature and you can see they are english).
Example - Edit a M6-1.0 and make it a 1/4-20. The hole changes, but the words in the feature tree still say M6-1.0.
SW 2007 SP 5.0 XP-Pro X64
Any ideas I could try?
Thanks!
RE: Feature tree not updating with hole wizard change
Ctrl+Q  ?
Did you manually alter the original hole name?
cheers
I think I remember that being a bug in '07, but I'm not sure.
-handleman, CSWP (The new, easy test)
corblimeylimey - Tried that and no, didn't manually alter the original hole name.
