Quickfield vs Maxwell SV
Hello everyone,
i am modeling a simple magnetic system with an U shaped yoke to pull an armature (see attached picture), i download quickfield and maxwell SV, i model the same geometry on both softwares, and i try to get the force exherted on the armature and i get different results, in quickfield i get a magnitude of .025N with an angle of 269 and with maxwell i get a magnitude of .039N with an angle of 270.5.
I already check and i have the same material properties and the same geometry dimensions and the same current density on the current carrying cable.
Am i missing something ? Boundary conditions maybe.
I know that quickfield calculate the integrals over 1 meter in the z direction, is the same thing for Maxwell SV ?
can this depth number be modified in Maxwell SV ?
If the software calculates 1N of force on the armature and is calculated over 1 meter in z direction it means if a wan to know the force if i had 50 cm depth in the z direction the force will be the half thats 1N/2= .5N ?
Any idea where i can find more info on understanding 2d FEA ?
Thanks in advanced ??
RE: Quickfield vs Maxwell SV
Try running a textbook (easy model and known answer) problem in each to figure out what is going on.
but i have another question, how will fringing affect the force exherted over the armature ?
what i think is that fringing will reduce the efective magnetic field on the armature reducing also the force, is this correct ?
