how do you compact soils to 95% max Proctor density?
You see this in geotech reports all the time...but how does the contractor actually do this compaction in the field? And how does he physically verify that he has compacted enough?
thanks
thanks
RE: how do you compact soils to 95% max Proctor density?
Dentity is typically verified by an independent testing company usin drive tubes or nucular gauges.
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
