Excel Help
Excel Help
I have a couple of questions so please bear with me,
First, can I set a value to a cell with words? Such as the word dog=1, and then have a total for dogs? Here is an example just incase...
Dog
Dog
Dog
Total dog=3
My next question is how can I make a formula that will give me the % of good and a % of bad. I thought about an if statement but I have three different conditions determining what is good and what is bad. The information is for anything less than -.630=bad, between -.5 and .5=good, and .629 and greater=bad.
I am stumped...and Google is not cooperating. Plus i feel like a am trying to over complicate things when it should really be easy. I am going to blame it on management making us come in when Fey is over land.
Dog
Dog
Dog
Total dog=3
RE: Excel Help
CODE
1 Dog
2 Rooster
3 Chicken
4 Dog
5 Pig
6 Dog
7 Cat
8
9
10 3
The formula in A10 is:
=COUNTIF(A1:A7,"Dog")
CODE
1 2 No Good
2 0.5 Good
3 -3 No Good
4 -0.25 Good
5 0 Good
6 -0.6 No Good
7 Bird #VALUE!
8 0.129 Good
9 0.2 Good
10 0 Good
11
12 60.00%
Formula in B1:
=IF(ABS(A1)<=0.5,"Good","No Good")
Formula in B12:
=COUNTIF(B1:B10,"Good")/10
-handleman, CSWP (The new, easy test)
RE: Excel Help
=if(a1="dog",1,"") then do a sum
Now if you just want to count the number of cells with dogs then you could use COUNTIF
=COUNTIF(A1:A5,"dog")
You can nest 7 IF statements so doing your % good and bad can easily be done.
=IF(C1<-0.63,"bad",IF(OR(C1>-0.5,C1<0.5),"good",IF(C1>0.629,"bad","")))
RE: Excel Help
Rnordquest, I am trying to use your formula:
Because it breaks everything down how I want it to be recognize but it is not working properly. Values below- .630=bad -.5 to .5 = good, also works fine. But the other .639 and above is not changing to bad. I have been trying to figure it out but everything I think seems to be the problem doesn't make and difference.
Thanks for all your help
RE: Excel Help
What about the numbers that are between your ranges? You have not defined the areas between ±0.63 and ±0.5
-Inf. to <0.63 = Bad
-0.63 to -0.5 = ???
>-0.5 to <0.5 = Good
0.5 to <0.629= ???
0.629 to Inf. = Bad
RE: Excel Help
RE: Excel Help
RE: Excel Help
CODE
