How to call a user subrutine written with Fortran
I've been working with ANSYS CFX only for a short period of time.
The problem I'm trying to solve implies a sensor so I've tried to solve Tutorial 17 first. This tutorial uses a subrutine which has been written with Fortran, but when I use the cfx5mkext command to create a shared library, , it doesn't create a subdirectory in my working directory as it should.
Maybe the problem is that I'm using ANSYS V110 and Compaq Visual Fortran 6.6.0. However, I've taken the steps that are indicated in "ANSYS help" to use this compiler instead of the Intel Fortran 9.0 compiler.
One thing that I find funny is that when I've open the Fortran file that appears in the tutorial, 3 errors where found.
Thnks in advance.
