ASTM and EN Testing Code
What is the differnece between ASTM Testing code and EN such as EN 10002 and EN 10045?
RE: ASTM and EN Testing Code
You need to obtain these standards and review them to learn the differences.  EN 10002-1 is 54 pages long, while ASTM E 8M is 22 pages long.  We can't summarize them for you in a short reply.  In general, you can obtain the actual mechanical properties of a material using each method.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
While both of them will give you mechanical properties they are not equivalent or interchangeable.  The test controls and calibrations are different.  the equipment is physically the same and the results are the same, but the methods are different.
Plymouth Tube
